Width of angled back on corner cab
Tim Massa
Postby Tim Massa » Wed, Nov 05 2014, 9:57AM
Would anyone be able to remind me if there is a way to change the width of the angled (center) back of the 90 degree corner cab? If it can be eliminated at all?
Tim
Scott G Vaal
Re: Width of angled back on corner cab
Postby Scott G Vaal » Wed, Nov 05 2014, 10:03AM
Tim,
This is controlled by the Corner Gap setting on the Corner Settings tab of construction settings. If you make it a larger value, the center back will get wider. If you set this to zero (0), it will remove it all together. Hope this helps.
Tim Massa
Postby Tim Massa » Thu, Nov 06 2014, 4:19PM
Thanks Scott!
Dennis Englert
Postby Dennis Englert » Fri, Nov 07 2014, 7:22AM
Also, the width of the center back is double the corner gap.
Dennis
Users browsing this forum: No registered users and 56 guests
