I am having a problem with the constraint manager on various cabinets. It does not matter if it is from within the job or pulled out of existing library. I will attach a cabinet that it occurs on.
I try to take the deck from this cabinet and add two more holes to the bottom center for leg levelers and than take it into constraint manager to properly place them to stay centered for future resizing. When I resize the cabinet either they do not stay in the center or some other screwy thing happens like the cabinet deck stays the original size even though the rest of the cabinet is the new size and the joinery gets screwed up.
Issue When Trying To Use Constraint Manager
- Vince Lisanti
- 2_ISLAND.jpg (25.79 KiB) Viewed 5741 times
- 2_ISLAND.hsf
- (1.04 MiB) Downloaded 615 times
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
32 GB RAM
- Vince Lisanti
Re: Issue When Trying To Use Constraint Manager
Or I will get the error message that says:
"There was some problem while regenerating the Deck
Press Yes to lose part editor cuts or press no to revert to the old cabinet"
32 GB RAM
32 GB RAM
- Vince Lisanti
It also does this when using a cabinet from the standard cabinets folder.
32 GB RAM
32 GB RAM
