Slide Holes Not Visible
Vince Lisanti
Postby Vince Lisanti » Tue, Mar 17 2015, 12:40PM
BRH_24D_1 DRW.jpg (16.12 KiB) Viewed 1064 times
BRH_24D_1 DRW.hsf
(1.75 MiB) Downloaded 79 times
I cannot get drawer slide holes to be visible in the upper partitions in this cabinet. They show up in the nest so I am assuming they would be cut, but I want to make sure and would also like to know if they are visible for anyone else.
Dell Precision M6500
Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz (8 CPUs), ~1.7GHz 4.00 GB RAM
NVIDIA Quadro FX 2800M
Windows 7 Professional 64-bit
Scott G Vaal
Re: Slide Holes Not Visible
Postby Scott G Vaal » Tue, Mar 17 2015, 3:32PM
Vince,
Your partitions are positioned past the inside edge of your left and right face frame stiles. This is because the 0.0156" (1/64th) scribe that you have applied plus 2 times the material thickness .75" (3/4") is wider than your FF stiles (overhangs the inside edge by .0156"). Since slide patterns are designed to position from the inside edge of the FF stiles, your scenario is causing the pattern to get buried into the partition. Do you need this small scribe?
Vince Lisanti
Postby Vince Lisanti » Tue, Mar 17 2015, 3:49PM
Thanks for the quick response Scott. That answers my question. I will do away with the 1/64" scribe on these cabinets.
Thanks again.
