notched shelf for hiding the shelf pins
alainalbert
Company Name: Woodoer Inc
Postby alainalbert » Sat, Mar 21 2015, 10:43PM
Is there any way to create a notch in the shelf that would hide the shelf pins like in the picture attached? I hate doing this in part editor and i suspect that there must be a better way.
thanks for your help
Nat Wheatley
Re: notched shelf for hiding the shelf pins
Postby Nat Wheatley » Sun, Mar 22 2015, 7:36AM
I'd try treating it as a fixed shelf with a modified RTA pattern.
Nat Wheatley
Postby Nat Wheatley » Sun, Mar 22 2015, 2:56PM
Sample file attached just to give an idea. You'd likely need to add a 'phantom' shelf to get the shelf holes in the sides of the cabinet, though you may be able to incorporate these into the modified RTA pattern as well.
Shelf Pin.hsf
(236.02 KiB) Downloaded 240 times
alainalbert
Postby alainalbert » Wed, Mar 25 2015, 10:22PM
Hi Nat
that's very clever, thank you very much. I'll try to see if i can work with this given that the rest of my cabinet is connected using regular KD fittings.
Thomas strembitsky
Postby Thomas strembitsky » Sat, Apr 04 2015, 3:23PM
could you post the ptn file for that?
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Nat Wheatley
Postby Nat Wheatley » Sat, Apr 04 2015, 3:36PM
Not sure how to attach a ptn file, but I just drew a rectangle with coordinates in millimeters (0,-2.5) (11, 2.5) with a negative depth of 6. This would likely need to be adjusted, but will give the idea.
Users browsing this forum: No registered users and 38 guests
