I have a cabinet that when you use the crown editor area won't put the corners of the crown together. The problem happens because I have face frame offsets for the side pc of plywood. This puts the plywood side in from the edge of the cabinet by 3/4". Then there is a panel that is applied on the plywood making it flush the the edge of the FF.
But the return pc of crown stays following the plywood. I can't get this crown to push out and look like it is wrapped around the panel. It is sunk inside it.
I can adjust the scribe of the front pc of crown to make that look correct, but not the return. That only has scribe functions for front and rear.
Am I forced to apply a pc of crown manually there? Or am I missing something?
Misaligned Crown molding
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Misaligned Crown molding
Leo,
Can you post the cabinet so I can see the exact situation.
Hope this is it. It's so buried in the file structure of the computer
- LO Pantry upper.hsf
- (644.02 KiB) Downloaded 323 times
- LO Pantry upper.jpg (15.34 KiB) Viewed 5314 times
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Leo,
If you need it for looks, then yes, your best option is a display molding. If you did not need it for looks, it is the correct size already, just positioned over by the face frame scribe.
Ya, it's just for the presentation. I was wondering why my upper rail on the panel looked so fat. I zoomed in and the crown was buried.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
