Part editor question/suggestion
Nick Sollecito
Postby Nick Sollecito » Tue, Apr 28 2015, 7:03AM
Is there a way to add holes to a part incrementally in the part editor? For example, it would be helpful when adding holes for slides. After the first hole is located it would be much easier to move over to the next location by the incremental dimension rather than calculating the absolute location.
Thanks!
Nick Sollecito
Home Genius
http://www.MyHomeGenius.com
ynd@comcast.net
Scott G Vaal
Re: Part editor question/suggestion
Postby Scott G Vaal » Tue, Apr 28 2015, 10:02AM
Nick,
You can do this using the Contour area of the Part Editor.
1.) Go to the Part Editor, then select the Contour area icon.
2.) Create the first hole you want using the Circle/Arc mode.
3.) Now, select this circle (highlighted green) and then select the Move/Copy icon (ensure that the option is set to Copy).
4.) For the point to translate from, just type in 0,0 and then press enter.
5.) For the point to translate to, set the option to INC, then type something like 2.5,0 and press enter. It will move/copy incrementally from the 1st hole. then just type 0,0 again and press enter, then enter in the next incremental position you want it to copy to (it will keep copying the last one moved/copied by the incremental amount you type in). Hope this helps.
Also, just want to make sure you are aware of the hardware hole editor where you can create any slide pattern and then have it automatically add the holes for the slides when adding drawer fronts and drawer boxes.
Nick Sollecito
Postby Nick Sollecito » Tue, Apr 28 2015, 10:20AM
That's great! I knew there had to be a solution I just couldn't figure it out. I do know about the slide pattern.
Thank you. That will save me a lot of time!
Nick
Nat Wheatley
Postby Nat Wheatley » Wed, Apr 29 2015, 5:30AM
Would it be possible to add this feature to the Hardware Hole Editor?
Postby Kerry Fullington » Wed, Apr 29 2015, 10:21AM
Nat
In the Hardware Hole Editor,
Create your hole then go to select mode and select it
Right Click then Choose Edit Move Increment
Enter the distance you want to move then use the arrow keys to move it.
Nat Wheatley
Postby Nat Wheatley » Wed, Apr 29 2015, 11:51AM
Kerry,
When I hit the arrow key, then entire screen seems to shift my the move increment. When I hold the shift key and hit the arrow, the selected hole moves, but doesn't leave a copy at the original location. Is there a way for it to leave a copy?
Nat
Postby Kerry Fullington » Wed, Apr 29 2015, 12:21PM
Nat,
It won't make a copy but you can create multiple holes on top of each other (say at origin 0,0) then select them one at a time and use move increment to place them.
Sorry I forgot about the shift key.
Nat Wheatley
Postby Nat Wheatley » Wed, Apr 29 2015, 1:04PM
That'll work, thanks Kerry
Users browsing this forum: No registered users and 37 guests
