Aventos - style doors
Mark Hesketh
Company Name: Paris Kitchens
Postby Mark Hesketh » Thu, Jun 11 2015, 7:37AM
IS there a way to have a door automatically add the proper hardware holes for an Aventos-style swing-up door? It would have to be related to the top of the door only... We add these to a lot of different cabinets and it would be much easier if we could just select a different hardware pattern when adding the door.
I'm thinking for the lift mechanisms that mount to the gables as well as the hinges that may/may not be needed across the top of the cabinet.
ACE Mirabel Mike
Company Name: ACE Concept inc
Re: Aventos - style doors
Postby ACE Mirabel Mike » Sat, May 11 2019, 9:05AM
Hi Mark,
I'm installing Aventos as well.
Did you received any answer so far on this topic ?
Did you find a way to work this out ?
Thank you
Michel Pilon
ACE Concept inc.
Mark Hesketh
Postby Mark Hesketh » Mon, May 13 2019, 6:50AM
No, I haven't figured out a way to do it through applied hardware settings or anything.
I ended up making a couple of Part Editor "blocks" that I can bring in and then use Constraint Manager to move them into the correct spot. It's a couple of extra steps, but it works
Users browsing this forum: Majestic-12 [Bot] and 47 guests
