How to determine exact material thickness used before
Daren LaBranche
Company Name: Drawn to Wood
Postby Daren LaBranche » Mon, Jul 06 2015, 7:05PM
I'm wondering if anyone knows how to determine the ACTUAL material thickness used in a TWD file from a past job? I use generic material thicknesses in the library and then usually change those to exact thicknesses at the shop, where I simply mic the material when I create the TWD file.
But I'm not at the shop so I can't measure the material and I don't think eCabs retains any record in the library or the job of material thickness changes made during the TWD file creation. So I'm looking for a way to see the exact material thickness I used in a previous job, of which I have the TWD file from for my ShopBot, but I don't know where/how to look in that file.
Daren
Daren LaBranche
Re: How to determine exact material thickness used before
Postby Daren LaBranche » Mon, Jul 06 2015, 7:18PM
Never mind, I think I found it. For anyone that's interested, here's how I did it.
1) Load the TWD file (in my case, into the ShopBot Link).
2) Select the material using the selection filter (if there's more than one).
3) Nest the material.
4) Without the USB hasp installed on your computer, click 'Write to ShopBot'.
5) A window will open showing the code. Look for the line that starts with "&ZSHIFT" about 24 lines down from the top of the file and just above the line with the material name you exported from eCabs. In my case the 5/8" Birch ply was actually 0.607".
Cheers
tim lucas
Postby tim lucas » Mon, Jul 06 2015, 7:22PM
Load your TWD file in the link, nest it, then go into add sheet - there you can see the material and the thickness of what you used
Tim
www.TLCW.us
Daren LaBranche
Postby Daren LaBranche » Mon, Jul 06 2015, 7:23PM
This post should have probably been named "Determine exact material thickness used before from TWD file" but I can't change it.
Daren LaBranche
Postby Daren LaBranche » Mon, Jul 06 2015, 7:25PM
Oh sure, just another way to do something simpler AND easier! That's all I need.
:beer:
Thanks Tim
Users browsing this forum: No registered users and 30 guests
