IMPORT BATCH LIST
IMPORT BATCH LIST
I am trying to import a batch list of panels from open office saved in xls format. I followed the help file, but still can't get it to work. Any hints or tricks to get this to work.
Zach
Zach
- STOUT,VAUN DOOR PANEL TEST.xls
- Excel Batch Import
- (8.5 KiB) Downloaded 473 times
Lyndan Designs
Machining and CAD Services
Re: IMPORT BATCH LIST
Zach,
It works correctly for me if I create the directory named LD ACCESSORIES and save a cabinet named SKIN into it. Make sure your directory and cab name match (unmatched spellings or spaces will cause failure). Do you get any error message when you run it?
No error message nothing happens. I will double check the spelling and directories.
Zach
Zach
Lyndan Designs
Scott,
I tried renaming the directories and cabinet name and still nothing. I am not getting any errors. Is there anything else that could be causing this?
Zach
Zach
Lyndan Designs
- Company Name: Thermwood
You mentioned you were using open office. If you do not have excel install on your pc, you need to install excel viewer. It puts the proper dll on your pc that will allow for excel imports.
http://www.microsoft.com/en-us/download ... aspx?id=10
Rick Deskins
eCabinet Systems Programmer
Rick,
I went to import a batch today and now I am getting nothing again. It worked after I installed the excel viewer, but now nothing.
Any insight to why this is causing so many problems. Should I get a copy of excel and not use open office?
Zach
Zach
Lyndan Designs
Can you post your excel file you are trying to import?
Rick Deskins
Here is the file.
- DOOR PANEL TEST.xls
- (10.5 KiB) Downloaded 475 times
Lyndan Designs
You have a space after the directory name. May try removing the trailing space.
Rick Deskins
Rick,
I have tried renaming with and with out spaces still nothing is working. I have double checked spelling over and over, but still can't get it to work.
Lyndan Designs
Does this work for you?
- (22.5 KiB) Downloaded 438 times
Rick Deskins
Rick,
This time it gave me an error. "Error loading row 0 of c;\users\zach\downloads\door panel test.xls. Failed to load BEP.
Lyndan Designs
Rick,
I double checked the file you posted and realized that I had renamed the LD ACCESSORIES directory while playing around and it does work now.
Lyndan Designs
Glad to hear that it worked. All I did to your xls file is remove the space at the end of "LD ACCESSORIES".
Rick Deskins
