Copy contour
Shaun Just
Company Name: Not Just Kitchens LTD
Country: NEW ZEALAND
Copy contour
Post by Shaun Just »
Hi there,
Is there an easier way to copy a complete closed contour and enlarge or decrease the size for example, I make a 55mm frame and want to do a 47mm profiled edge on the inside, at the moment I create my 55mm edge and do the pocket cut, then I create edges and copy each inside edge by 8mm and then trim them together then do the profile cut, and thought there must be a easier way of doing this in one step? Any ideas?
please see attached photos
first profile
first profile
second profile
second profile
Shaun
tim lucas
Re: Copy contour
Post by tim lucas »
Are you familiar with the offset in part editor ?
www.TLCW.us
Shaun Just
Re: Copy contour
Hi tim,
Yeah very familiar with it, what I'm saying is it only offsets one line at a time not the whole box as such
Cheers
Scott Marshburn
Re: Copy contour
Post by Scott Marshburn »
You can offset the cutter by 8mm to the left or right of the pocket depending on the cut direction.
