Ecabs doesn't recognize mid stile once a cab is saved
Carmen Addamo
Postby Carmen Addamo » Fri, Apr 08 2016, 7:56PM
I built a standard face frame double door cabinet and saved it to my library. I then tried to edit the cabinet by adding a few partitions and a mid stile. I go to door editor and ecabs does not recognize the mid stile and treats the openings as one single opening even though I get seprate openings in FF editor. I actually keep getting a dialogue box saying I have a locked opening and cannot perform any editing on the cab after I install a mid stile. I'll just have to build a mid stile cab from scratch and save that one . No big deal i guess but do find it odd.
Re: Ecabs doesn't recognize mid stile once a cab is saved
Postby Kerry Fullington » Sat, Apr 09 2016, 7:02AM
Carmen,
The Shelf partition editor does not see face frame parts so if you add a mid stile in the FF editor it will not be recognized in the Shelf Partition editor. The Shelf partition editor only sees openings created by shelves and partitions. You can associate a partition or shelf to a mid stile or mid rail so that they move together. If you associate a partition to a mid stile and then lock the Face Frame opening, the opening in the shelf partition editor will also be locked.
Carmen Addamo
Postby Carmen Addamo » Sat, Apr 09 2016, 1:35PM
Kerry Thanks for the reply. You may be misunderstanding me or I you. What I was trying to say was once I created a single opening cabinet, no mid stiles, no partitions, and saved that cabinet I can no longer add a mid stile to the cabinet or even just a partition. The software views the original single opening cabinet as a locked opening. Even though I have not applied any opening locks. It will place the partition and/or stile but I will get an error locked opening prompt every time I move to a different editor or back to the main screen.
To create a two opening cabinet I have to go into the "Standard Cabinet" directory and create a two opening cabinet with partitions/mid stiles from the get go. Once saved I can then adjust opening sizes, install doors etc. as usual.
Rick Deskins
Company Name: Thermwood
Postby Rick Deskins » Mon, Apr 11 2016, 1:01PM
Can you post the broken cabinet file?
Rick Deskins
eCabinet Systems Programmer
Carmen Addamo
Postby Carmen Addamo » Tue, Apr 12 2016, 5:58AM
Rick, I'm sorry but I would need some instruction on how to post a file.
Rick Deskins
Postby Rick Deskins » Fri, Apr 15 2016, 7:18AM
When you post a reply, there is a tab toward the bottom of the page that says Upload Attachment. Click on that tab then Click on Choose File and browse for file you want to post. Then click Add the file to it to the post.
Rick Deskins
Carmen Addamo
Postby Carmen Addamo » Tue, Apr 26 2016, 6:04AM
Rick, Sorry about the delay in posting this. If you take this cabinet and try and install a partition, and mid stile, you will first notice the mid stile does not connect to the bottom rail. I have a negative float for the deck to act as a door stop. Then try to install a door and you will see it does not recognize the mid stile and you will start to get error prompts.
SD Upper.hsf
(486.02 KiB) Downloaded 48 times
