Best way to handle the staircase opening from the attic to 2nd floor
Carmen Addamo
Postby Carmen Addamo » Thu, Jul 21 2016, 3:40PM
Turning an attic into bedroom with large number of built-ins, custom bed etc. How would you handle the floor opening/stairs. I can only think to create a railing/knee wall around the location of the openings. Use a display cube to simulate an opening in the floor??
Scott Marshburn
Re: Best way to handle the staircase opening from the attic to 2nd floor
Postby Scott Marshburn » Thu, Jul 21 2016, 6:52PM
Hi Carmen. The method that you described seems like the quickest and easiest way to get the cabinets in the room and still give the customer a good idea of what the layout will look like. However, if presentation is what you are after. You can draw the walls the same height as the ceiling height, then use a display cube that is the same thickness as the floor, position the cube so that the top is at the same height as the second floor in your room . You can then cut a pocket in the cube for the stair opening. You can also use a display cube to create the stairs. This method is a lot more involved but should give you a very impressive presentation to show your customer. The screen shot is an example of using a cube for the floor. I hope this helps.
Carmen Addamo
Postby Carmen Addamo » Thu, Jul 21 2016, 8:48PM
Scott Thank you for the suggestions. Your ideas definitely helped me elevate my designs.
Scott Marshburn
Postby Scott Marshburn » Fri, Jul 22 2016, 7:12AM
Carmen Addamo wrote:Scott Thank you for the suggestions. Your ideas definitely helped me elevate my designs.
Thank you . I am glad I could help. Don't forget to post some pix when you get it drawn. I would like to see how it turned out.
Postby Kerry Fullington » Sat, Jul 23 2016, 10:45AM
Carmen,
I have this staircase as a Display Object if it would help. It is scalable.
Carmen Addamo
Postby Carmen Addamo » Mon, Jul 25 2016, 8:13AM
Kerry that would be great. Thank you for offering.
Postby Kerry Fullington » Mon, Jul 25 2016, 12:25PM
Carmen,
It is on my computer at home. I will send it tonight.
Clint Buechlein
Company Name: Thermwood Corp
Postby Clint Buechlein » Mon, Jul 25 2016, 1:31PM
Carmen,
Here is a link to another thread that has a downloadable .stl for a staircase. You'll have to load each piece into the Display Part Editor and modify textures for each piece.
viewtopic.php?f=5&t=11978&p=63939&hilit=stairs#p63939
Here's a couple pictures of the staircase that I used.
Postby Kerry Fullington » Mon, Jul 25 2016, 6:27PM
Here is the stair display part.
staircase 1.hsf
(2.15 MiB) Downloaded 38 times
Users browsing this forum: Google [Bot] and 7 guests
