Double door reveals
Chris B Campbell
Double door reveals
Postby Chris B Campbell » Sat, Aug 20 2016, 11:26AM
Is there a way to get a different reveal on one side of a double door. For instance I have a double door cabinet I need 0 reveal on the left and .1875 on the right. Dialog box only gives and hinge side reveal and open side reveal, in this instance both sides are hinged. I tried deleting shelves, install a partition and made the adjustments in the dialog, this worked until I deleted the partition then the doors disappeared.
This is a Euro-style cab.
Any help?
Chris
Re: Double door reveals
Postby Forrest Chapman » Sat, Aug 20 2016, 11:44AM
Chris, after you add the doors click on (highlight) the one you want to change. Go into construction settings and make your change for the hinge side. Understand that if you ever delete the doors and add them back it will use this new setting for both sides.
Carmen Addamo
Postby Carmen Addamo » Mon, Aug 22 2016, 6:41AM
Forrest has a good solution. When I have the situation you describe I always just make the reveal settings so the reveal total is first calculated and then divide equally (divide by 3 in your double door case). This is so both doors are the same width and only their location on the cabinet is slightly shifted. Less confusion IMO whether you build in house or outsource. Also even though no one would notice it does not seem correct from a design standpoint to have one door 18" and the other 18 1/8" on the same cab.
Postby Forrest Chapman » Mon, Aug 22 2016, 8:59AM
Carmen, Thanks for catching that. It used to not function that way so I didn't even look at it this time. I'll ask the programmers about it.
Postby Kerry Fullington » Mon, Aug 22 2016, 10:19AM
Chris,
Select your opening in the Door Editor
Click on the Add Double door Button
The Add double door Dialogue box will appear and here you can enter a left Reveal and a right reveal
Postby Forrest Chapman » Mon, Aug 22 2016, 10:30AM
YES! I knew there was a way I used to do it. Thanks Kerry.
Chris B Campbell
Postby Chris B Campbell » Mon, Aug 22 2016, 4:50PM
Thank You... Double click, who wood'a guessed. :roll:
Thanks Again ,
Chris
Users browsing this forum: Majestic-12 [Bot] and 50 guests
