Cabinets losing edgebanding
Jeremy Schiffer
Postby Jeremy Schiffer » Tue, Dec 13 2016, 11:28AM
We've been having this issue a lot lately, with cabinets not showing edgebanding on the labels at the machines. Load these cabinets into the cabinet editor, and apparently all is well. Write a TWD file from them, and the one I have named NO EB will not show edgebanding on the cabinet box parts. It does show it on the drawer fronts and drawer boxes.
Otherwise, these cabinets were created from the same seed cabinet, and are basically identical.
Could someone please take a look "under the hood" at these? Other than seeing that one works and one doesn't, there's not much more I can troubleshoot, since according to the Cabinet Editor, they are fine.
Thanks!
NO EB.hsf
(1.82 MiB) Downloaded 58 times
HAS EB.hsf
(2.95 MiB) Downloaded 37 times
Jim Carter
Company Name: Jim Carter Corp.
Re: Cabinets losing edgebanding
Postby Jim Carter » Tue, Dec 13 2016, 12:47PM
I came on the forum this morning to try to solve this very same problem.
I wonder if there is a connection with the cabinet body being lost when returning to batch file with "add no changes to batch".
I am using windows 7 and I see there is a patch. maybee this is will help .
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Jeremy Schiffer
Postby Jeremy Schiffer » Tue, Dec 13 2016, 2:33PM
We're using Win 8.1 on our design computers, and this problem is happening both in batch jobs and custom layout jobs. We've not been able to find a method to its madness yet...
Jim Carter
Postby Jim Carter » Tue, Dec 13 2016, 2:52PM
version 6.1.3 made the problem worse.
error messages
there was an error recreating part
creat outling body failed
re... body type nknown for outline edbes
infalid body in generatecncoutline
loose part editor cuts .....
973-224-0221
Jeremy Schiffer
Postby Jeremy Schiffer » Wed, Dec 14 2016, 3:52PM
Okay, I have some more info. Take the cabinet "NO EB" to the cabinet editor, right click and select Edit Material A side. Click on any of the cabinet box parts, and they will NOT highlight as they are supposed to. (The drawer fronts will)
So the lack of edgebanding seems to be related to this material A side issue. Regenerating the cabinet fixes it. We have this happen in nearly every job lately, I'd love to get to the root of it.
Rick Deskins
Company Name: Thermwood
Postby Rick Deskins » Thu, Dec 15 2016, 2:02PM
Jim Carter wrote:I came on the forum this morning to try to solve this very same problem.
This problem that was in 6.1.2, also affect the custom layouts as well.
Rick Deskins
eCabinet Systems Programmer
Rick Deskins
Postby Rick Deskins » Thu, Dec 15 2016, 2:19PM
Jeremy Schiffer wrote:Okay, I have some more info. Take the cabinet "NO EB" to the cabinet editor, right click and select Edit Material A side. Click on any of the cabinet box parts, and they will NOT highlight as they are supposed to. (The drawer fronts will)
Yes, a regen will fix it. It has lost some of the part bodies, and regen restores them. If you have a batch or room that you want to force a regen of all the cabinets, you can select all cabinets, go to Adj Features->Global Item Modication. Check Always Regen and click ok.
Do you happen to know what changes you have make to the NO EB cabinet? I saw that I was saved in Beta2, RC1, and 6.1.3.
Rick Deskins
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Dec 15 2016, 4:01PM
Rick, I haven't yet figured out at what point it loses the information. I watch for it to happen, it doesn't, and as soon as I turn my back, another few cabinets show up with no EB. Perhaps regenerating our entire library and re-saving will help.
These two cabinets were from one of our cutting customers - but they are our library cabinets. So I can't say exactly what the difference between the two is. They appear identical except that one (the one that the EB shows up on) has a filler attached to the side of it.
