cutlist and nest show different quanity
- Company Name: woodland Kitchens NH
Hi all, I am working on a kitchen now that I am about to order the wood to build. When I check my cut list it says I need 10 sheets of body ply then i go to nesting and have it preform nest. then it shows 8 sheets, now when i check cut list again in nest area it says 8 sheets also. Does anyone know why this happens? Thanks again for any help all
Re: cutlist and nest show different quanity
If you create the cutlist before nesting, the number you get is an estimate. Always run the nest first, then the cutlist.
Dave Egnoski
Richmond Cabinet & Millwork
Great thank you so much. I can see clearly now !
