Diagonal corner cabinet problems
Stuart Douglas
Postby Stuart Douglas » Tue, Apr 10 2018, 8:28AM
I have this cabinet that displays correctly, but does not nest or cut correctly. The top, deck, and fixed shelves are nested and defined to cut as pieces that are only a quarter of an inch wide, despite being correctly displayed in ECabS. Not sure how to remedy, or if I'll have to design this again from scratch in a different manner. Anyone run into this problem before?
diag cab.zip
(167.64 KiB) Downloaded 58 times
Joe Soto
Re: Diagonal corner cabinet problems
Postby Joe Soto » Tue, Apr 10 2018, 11:17AM
Not sure why but change if you change your blind dado placement from 2.19" to 2.25" it will fix your cabinet.
Stuart Douglas
Postby Stuart Douglas » Tue, Apr 10 2018, 11:33AM
Joe Soto wrote:Not sure why but change if you change your blind dado placement from 2.19" to 2.25" it will fix your cabinet.
That is a strange solution, but it works! I had set those blind dado insets to remove the tab created at the back of the shelf (and the top and deck, incidentally) and never looked at them again. Thanks for sleuthing that out. :beer:
