In Need of Tall Frameless Cabinet
Does anyone have a tall frameless cabinet that I can use? There isn't one in my Standard Cabinet Library for some reason.
Re: In Need of Tall Frameless Cabinet
Nevermind...found the libraires online...
- Brad McIntosh
Nat,
If I am not mistaken, most users will simply take a Frameless Base cabinet and increase its height to the required "Tall Cabinet" size. They will then save it to their library with the appropriate name.
Ok, thanks. I wasn't sure if I'd be able to add crown molding to a base cabinet. I'm just getting into the drawing side of the program, and haven't explored adding moldings yet...
Nat
Nat
Yes sir, you can add crown to a base cab and you can add light rail to a wall cabinet using the lower or base molding.
www.TLCW.us
www.TLCW.us
Thanks Tim!
