Create Seam?
Nat Wheatley
Create Seam?
Postby Nat Wheatley » Thu, Aug 02 2018, 1:58PM
I realize that this may be a long shot, but is there a way to create a seam in a part? In other words break a part into 2 pieces when it's longer than the sheet stock that it will be cut from.
tim lucas
Re: Create Seam?
Postby tim lucas » Fri, Aug 03 2018, 5:40AM
yes, but you will have to treat it as an assembly using 2 parts
www.TLCW.us
Carmen Addamo
Re: Create Seam?
Postby Carmen Addamo » Mon, Aug 06 2018, 5:49AM
You can use a stretcher. For example if you have a cabinet that requires a wider/longer back than a piece of sheet stock. Replace the back with two stretchers or give the back an inset that will size it under the max sheet size and add a stretcher for the remaining opening.
Nat Wheatley
Re: Create Seam?
Postby Nat Wheatley » Mon, Aug 06 2018, 6:20AM
That sounds promising, I'll give it a try. Thanks very much.
Users browsing this forum: No registered users and 31 guests
