Blind dado flip of not cutting correctly
Jesse Ogburn
Company Name: Ogburns Cabinet Shop Inc
Postby Jesse Ogburn » Thu, Aug 23 2018, 12:29PM
Hi guys, I have a little problem with blind dadoes when I have to do a flip operation on a part. The tongue is cut on the first side of the sheet and then when I flip the part to cut the thickness off of the tongue it cuts a big gouge into the part at an angle. I will attach a picture so you can see what I mean.
Is there something I don't have something set up correctly or is it something else?
Jesse
Ralph Balanik
Company Name: Ralph Balanik
Re: Blind dado flip of not cutting correctly
Postby Ralph Balanik » Fri, Aug 24 2018, 12:31PM
Really hard to know where to begin until more info is provided. What machine are you using? How are you setup? what kind of hold down system do you have? Are you doing flip ops first or last? Maybe a picture of the machine. Are you using different tooling for different operations?
Jeremy Schiffer
Postby Jeremy Schiffer » Tue, Aug 28 2018, 2:32PM
First thing I'd do there is measure the popup pin locations accurately and make sure they are correct in the THM software.
Postby Forrest Chapman » Tue, Aug 28 2018, 3:38PM
Maybe something to do with the ramp in settings?
Jesse Ogburn
Postby Jesse Ogburn » Wed, Aug 29 2018, 5:03AM
Ralph Balanik wrote:Really hard to know where to begin until more info is provided. What machine are you using? How are you setup? what kind of hold down system do you have? Are you doing flip ops first or last? Maybe a picture of the machine. Are you using different tooling for different operations?
Ok, I'm back...
1. I am using a model 45
2. I cut the parts out of the full sheet and then flip the double sided parts at the end using a 902 offset and a square
3. I have a vacuum hold down, or in the case of small parts a vacuum and double faced tape hold down
4. I am using a 3/8" down cut end mill for the blind dado operations. Since, I'm in 3/4 plywood that means that I am doing the blind dado tongue with one pass.
I don't think it's the ramp in settings because it does it after it cuts the tongue. It almost seems like the cutter compensation turns off before the tool lifts out of the wood. But I don't know why it would go back to it's starting point then?
I will include the thermwood file in case someone would want to check it out. It's the cabinet top, which looks like a stringer and also the partition that has cuts on both sides.
Gabler-Vanity.zip
(302.22 KiB) Downloaded 149 times
Clint Buechlein
Company Name: Thermwood Corp
Postby Clint Buechlein » Wed, Aug 29 2018, 7:36AM
Jesse,
What version of Control Nesting are you on?
Ralph Balanik
Postby Ralph Balanik » Wed, Aug 29 2018, 10:33AM
Jesse,
I am not familiar with your machine so I cannot offer much. I work with a ShopBot and I do a lot of flip ops. That does not mean that I haven't had problems. :lol: Some of the problems that I had were tooling size. I could cut with 1/4 inch but not 3/8. When I pocketed I had to change direction of cut from inside out to outside in. I also do all of my flip ops first then I only have to flip the sheet once and do not have to handle each piece separately. There were bugs in the shopbot link which I was able to discover with help from THermwood. Some of them may have been fixed in a new release but I don't play with something that works so I haven't tried going back to other settings. I would like to see the actual esj or hsf file because when I tried to load your twd it said that I didn't have tooling to do a particular pocket operation that you have in your cabinets. It would be more for my curiosity than to help you but maybe? I hope that clint will have some amswers for you.
Jesse Ogburn
Postby Jesse Ogburn » Wed, Aug 29 2018, 11:49AM
Clint Buechlein wrote:Jesse,
I have v6.06, but this has happened in the last couple of versions as well. Generally, I try to avoid creating flip operations to save time so I didn't worry about it too much, but it seems we're doing more of that kind of thing recently.
Clint Buechlein
Postby Clint Buechlein » Wed, Aug 29 2018, 11:54AM
Can you post the actual CNC code you ran? Unless you have changed it, the default save location is D:\data\Rolling_Nest\Cnc-Files. If there are multiple sheets, let me know which sheet it was on to save me a great deal of time. May need other stuff, but we will start with that.
Jesse Ogburn
Postby Jesse Ogburn » Wed, Aug 29 2018, 12:19PM
Clint Buechlein wrote:Can you post the actual CNC code you ran? Unless you have changed it, the default save location is D:\data\Rolling_Nest\Cnc-Files. If there are multiple sheets, let me know which sheet it was on to save me a great deal of time. May need other stuff, but we will start with that.
Alright here is the CNC code as well as the original Ecabinets file from which I generated the code. I marked the line in the cnc code with ### so if you search the file for that you can see the part of the code that is doing the odd cut.
Thanks!
Gabler Files.zip
(653.98 KiB) Downloaded 147 times
Clint Buechlein
Postby Clint Buechlein » Wed, Aug 29 2018, 3:03PM
It wrote an odd line of code in there. Can you load the file into Control Nesting and then get me an export? Once its loaded go to File and then choose Export. Save it somewhere you can find it. If you can post it, that would be great, if you can't, you can upload it here http://www.ecabinetsystems.com/eCabinet ... FileUpload. If you have to upload it, let me know when you do.
Jesse Ogburn
Postby Jesse Ogburn » Thu, Aug 30 2018, 1:06PM
Clint Buechlein wrote:It wrote an odd line of code in there. Can you load the file into Control Nesting and then get me an export? Once its loaded go to File and then choose Export. Save it somewhere you can find it. If you can post it, that would be great, if you can't, you can upload it here http://www.ecabinetsystems.com/eCabinet ... FileUpload. If you have to upload it, let me know when you do.
Here you go!
Export File.zip
(195.02 KiB) Downloaded 143 times
Clint Buechlein
Postby Clint Buechlein » Thu, Aug 30 2018, 1:56PM
Something is going on with the Single Pass Tenon Cuts being checked. I'll have to send it to the software engineers to have a look at. Looks like unchecking that setting lets it work correctly, just a bit more machining time to cuts the tenons.
Jesse Ogburn
Postby Jesse Ogburn » Thu, Aug 30 2018, 2:30PM
Ok, I'll check that box and keep making chips! 8) Thanks for your help Clint
