Pocket Cutting Off Profiled Edge
Troy Hollinshead
Company Name: Leidys Custom Woodworking
Postby Troy Hollinshead » Thu, Sep 06 2018, 9:21AM
Hi Guys,
I'm not good at describing my issue and I hope that the photo shows whats going on. Ive included the ecabs file, A DXF drawing of the Front and Back sides and also the Profile Tool that I made (The Modeling Tool At the CNC Is a .5 Downsheer Bit). I've Started over 2 times trying to get different results but both times I got the same result.
Troy Hollinshead
Tray.zip
(897.12 KiB) Downloaded 221 times
Clint Buechlein
Company Name: Thermwood Corp
Re: Pocket Cutting Off Profiled Edge
Postby Clint Buechlein » Thu, Sep 06 2018, 9:46AM
Troy,
Can you post an export from Control Nesting? Can I also get a picture of some settings in Profile Modeler? Open Profile Modeler, go to Operation and choose Defaults. Take a picture of that screen so I can get your defaults.
Clint Buechlein
Postby Clint Buechlein » Thu, Sep 06 2018, 10:38AM
Also worth noting for Troy and others, if you are bringing in geometry to Shape Manager or Contour Mode of Part Editor, it is worth looking at the DXF Option setting in the right click menu. Looking at Troy's part, I'd guess his setting is set to Import Polylines as Lines. This outputs all those black lines you see in the swept profile. If it the setting is Import Polylines as Arcs, it will come in as one arc.
Troy Hollinshead
Postby Troy Hollinshead » Thu, Sep 06 2018, 10:41AM
Sure Clint.....Attached are the files you asked for.
ControlNestandOperations.zip
(445.16 KiB) Downloaded 209 times
Clint Buechlein
Postby Clint Buechlein » Thu, Sep 06 2018, 11:06AM
Troy,
Not sure exactly whats going on with this one, I'll have to send it to the software engineers. The attached picture is the backplot of the code. Each of the white lines is the path the tool takes. So the center one that cut correctly has the correct shape. For whatever reason the outer two circles are going the wrong way. I'll let you know when I hear back from the engineers.
Troy Hollinshead
Postby Troy Hollinshead » Thu, Sep 06 2018, 11:33AM
Clint,
Thanks a million...I've been going in circles.
Troy
Troy Hollinshead
Postby Troy Hollinshead » Fri, Sep 14 2018, 7:28AM
Clint,
Have you heard anything from the engineers?
Troy
Clint Buechlein
Postby Clint Buechlein » Fri, Sep 14 2018, 10:27AM
Troy Hollinshead wrote:Clint,
Troy
Troy,
They see the issue, but are backlogged with other software updates. I'm working to see if I can find a work around. I was out earlier this week and have been playing catch up.
Clint Buechlein
Postby Clint Buechlein » Thu, Sep 27 2018, 8:49AM
Troy,
We just released a new version of Control Nesting that should correct the issue. Link to download the install http://www.thermwood.com/updates_contro ... g_home.htm.
Troy Hollinshead
Postby Troy Hollinshead » Fri, Sep 28 2018, 6:28AM
Clint,
will that same link for my THM Desktop also?
Clint Buechlein
Postby Clint Buechlein » Fri, Sep 28 2018, 7:11AM
Yes, same install for desktop version and machine.
Troy Hollinshead
Postby Troy Hollinshead » Fri, Oct 12 2018, 6:42AM
Clint,
The Update did the trick my part cut fine. Now the customer made some changes and added another pocket with profiled edge and I get "Sweep not possible" error box. Any ideas?
Troy
Clint Buechlein
Postby Clint Buechlein » Fri, Oct 12 2018, 11:25AM
Troy,
Can you post the cabinet with the contour lines on it that you are trying to sweep? Also can you post the tool you are trying to sweep? I may be heading out early today so it may be Monday before I can take a look at it.
Troy Hollinshead
Postby Troy Hollinshead » Mon, Oct 22 2018, 6:51AM
Clint,
Sorry It took me a while to get back to you. I modified my drawing and was waiting on the outcome from the shop.
Attached is a picture of the changes I made to my drawing to get it to cut perfectly.
Thanks Again!
Troy
Users browsing this forum: No registered users and 50 guests
