cross section view
David Egnoski
cross section view
Postby David Egnoski » Fri, Oct 19 2018, 11:28AM
Can anyone explain why the Cross Section View options are grayed out? The help instructions are pretty clear. The cabinet is selected. The red line never appears.
Dave Egnoski
Richmond Cabinet & Millwork
Clint Buechlein
Company Name: Thermwood Corp
Re: cross section view
Postby Clint Buechlein » Fri, Oct 19 2018, 1:00PM
Dave,
Cross section needs to be done from the front view of a wall. The wall must be selected and be at a flat view, not rotated.
David Egnoski
Postby David Egnoski » Fri, Oct 19 2018, 1:03PM
So I can't just take one cabinet to the LDE and get a cross section?
Thanks for the info.
Dave
Dave Egnoski
Postby Forrest Chapman » Sat, Oct 20 2018, 11:36AM
Hi David, you can take a single cabinet into LDE and rotate it 90 degrees. You can even select a side and hide it so as to see the internals.
Hope that helps, Forrest
David Egnoski
Postby David Egnoski » Sat, Oct 20 2018, 2:46PM
Thanks Forrest. That's what I ended up doing. Just thought the ability to use the cross section tool would be cool.
Dave Egnoski
Daren LaBranche
Company Name: Drawn to Wood
Postby Daren LaBranche » Mon, Nov 19 2018, 10:59AM
I too was wondering why it's in the right-click context menu in the Line Drawing Editor but greyed out! Kinda like a big tease. Why not just remove it from that menu in the LDE if it doesn't work there anyway?
