Since the upgrade every time I bring a board into the part editor it gets cut off. It goes in as the entire board, but very quickly you can see more than half the board disappear from view. And it's gone dimensionally, not just hidden from view. Doesn't happen with panels or cubes, just board stock.
Here's a quick video I took of the problem.
https://youtu.be/uD6pH7aXR-U
Board stock getting cut off in Part Editor
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Board stock getting cut off in Part Editor
Leo,
I see the same thing. I'll pass it along to the software engineers and go from there. It seems as though it is still there, but being rotated and cut away. You can use the Delete tool and choose Geometry Cut. The area that has been removed will show so you can bring it back. It still gets kind of weird coming out of Part Editor, but it is there at least.
Great, because I've already updated my video driver. If it wasn't that I don't know what it might be. Using panel stock is a pain because it gets nested. Thanks
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
I'm having this issue again. It's with a board stock. I can see how it's being rotated when I bring it into the Contour area of the part editor. I tried editing it there but it doesn't work.
It seems if I bring in cabinet parts I don't have this issue. I just tried a cube and it also doesn't have issues.
So it seems the problem is only with board stock
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
