Can not open ecabinets
Edward Kowalski
Postby Edward Kowalski » Fri, Apr 05 2019, 10:12AM
When I try to open ecabinet systems I get this message DAO Exception Thrown can not open ecabinets The microsoft Jet Database engine stopped the process because you and another user are attempting to change the same data
at the same time.
Scott Marshburn
Re: Can not open ecabinets
Postby Scott Marshburn » Fri, Apr 05 2019, 3:45PM
Hi Edward. Try running the repair option for ecabinets in your control panel under add/remove programs.
Edward Kowalski
Postby Edward Kowalski » Sat, Apr 06 2019, 11:45AM
Thanks Scott Tried that also tried system restore to prior date, uninstall, reinstall, remove all in registry reinstall, i0bit uninstaller, reinstalled seems to be something to do with Ms access data base. Reinstall upgrade to access no luck Hopefully somebody from Thermwood will chime in.
searched forums for DAO found some help but that did not work either
David Egnoski
Postby David Egnoski » Sat, Apr 06 2019, 12:33PM
Just fishing here but give this a try. Uninstall eCabinets, then look in C:\ProgramData\Thermwood\eCabinet Systems for any files ending in .mdb or .ldb. If you see any, delete them. Install eCabinets and give it a try.
If the uninstall removes that directory completly, I'm all wet.
Dave Egnoski
Richmond Cabinet & Millwork
Edward Kowalski
Postby Edward Kowalski » Sat, Apr 06 2019, 2:31PM
Thanks Dave but No luck
Edward Kowalski
Postby Edward Kowalski » Tue, Apr 09 2019, 10:36AM
Fixed Renamed localstore.mdb then ran repair. Thanks for all your help
Users browsing this forum: No registered users and 64 guests
