Error message lacking info
David Egnoski
Postby David Egnoski » Tue, Apr 16 2019, 2:28PM
It would be helpful if this dialog box contained the name of the cabinet with the problem. Any chance to get this added?
Thank you.
Error Message.pdf
(174.94 KiB) Downloaded 56 times
Dave Egnoski
Richmond Cabinet & Millwork
Thomas strembitsky
Re: Error message lacking info
Postby Thomas strembitsky » Tue, Apr 16 2019, 4:27PM
its probably a corner cabinet with a clipped corner I get this all the time....
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Joe Soto
Postby Joe Soto » Fri, Apr 19 2019, 8:33AM
Same issue in the change materials in the room area. An error saying a constraint can't be applied and will be removed or a locked opening wont allow the change. No idea as to what part or cabinet. Probably more annoying is when that dialog pops up, it stops working until you hit ok. Sometimes changing a material takes several minutes so I walk away to do other things and come back to see the error box waiting on me. It would be nice if it would make all the possible changes and then give a list of issues similar to how the global item modification tab does.
