Its probably just me, but in the attached, the top inset is set to 200mm, left side top flush and left back flush.
It is sticking up by 100mm, half the actual specified distance. And the end has descended by 100mm which should be flush?
putting insets of 100mm top and bottom of the end rectifies the settings
Thanking you
Mark
Left end construction setting
- aaa.hsf
- (1.44 MiB) Downloaded 324 times
Re: Left end construction setting
Mark,
You're supposed to find this stuff before release . In theory it should work, though I've never tried something like this before. I've got it repeating a standard cabinet, so I'll send it to the software engineers.
If only things behaved the way they are supposed to.
Life would be much simpler.
Job Done
Job Done
