Hi guys,
By the way still waiting for V5 up here in Montreal, QC, Canada.
I want to create closet space with the wall editor, I make three wall and the forth on (which is the one with the doors) is just a header 80'' from the floor.
I cut out the necessary rectangle from the wall, so far so good, then I go back to the Custom Layout and it leaves what seems to be a shadow of the top wall portion (see attachment).
How can I gat rid of the shadow?
Thanks in advance for your help.
Francis
Wall editor problem!
- Christ room.jpg (53.8 KiB) Viewed 5672 times
Francis Gaudreau
Montreal, Qc
Montreal, Qc
Hi Dan,
I am unsure since my posting was in August. Email your eCabinet job and steps to reproduce this to cabinets@thermwood.com
thanks,
thanks,
Jason,
I've sent the files. Thanks for looking into them.
I believe I have a more accurate description of what is happening: the texture that is supposed to be covering the the surface of the cut portion at the top of the header wall is instead being applied at floor level. It's not a full-thickness wall assembly appearing at floor level, it's just the \"coat of paint\" that belongs to the associated wall section above. Gravity just kinda sucked it down
Thanks again,
Dan
Thanks again,
Dan
