MULTIPLE ROOM LAYOUTS
Greg Olson
Postby Greg Olson » Thu, Jan 25 2007, 7:37PM
I have been using this program for about a week.
Is it possible to create multiple rooms on the same job file? For instance seperating kitchen and baths when going to the line drawing editor. Right now to seperate the items going to the line drawing editor you either have to select certain cabinets or a single wall, but you cant select multiple walls to complete a single room, and when you select the room to go to the LDE all the cabinets and walls go to it.
Please Help
Todd Miller
Postby Todd Miller » Fri, Jan 26 2007, 10:11AM
Greg,
Each room would need to be created as a separate job. We do not have a multiple room/floor format at this time.
Greg Olson
Postby Greg Olson » Fri, Jan 26 2007, 6:32PM
Todd,
Thanks, I have been trying to figure out how to make new roooms and couldn't figure it out, thanks for helping me out.
Greg Olson
Postby Greg Olson » Fri, Jan 26 2007, 6:33PM
Todd,
Postby Rick Palechuk » Fri, Jan 26 2007, 9:16PM
Hopefully Todd is in his happy place right now. :lol:
David Norton
Postby David Norton » Sat, Jan 27 2007, 8:27AM
Actually there are work arounds to this problem . When I need to show more than one room I create a floor plan in wall editor. separating interior walls by an inch or so. Then change the direction of build to the walls as necessary.
This is one I did a fews yrs. ago when I 1st started using Ecabs.
Screen shot.jpg (104.91 KiB) Viewed 2123 times
Dave Norton
Brian Bauer
Postby Brian Bauer » Sat, Jan 27 2007, 11:49AM
David I have done the same also just opened the walls up like a peeled orange to show all of the cabinetry in a house at one time in one place and it all nests at the same time.
Brian
Michael Yeargain
Postby Michael Yeargain » Sat, Jan 27 2007, 12:42PM
I topically do all the similar cabinetry in the same job. For example all the yucky melamine/white cabinetry such as bath, laundry; I do on one job. Using the same technique as David Norton. Just draw walls wherever they fit to do the job. And similarly all the kitchen/stained great rooms/stained etc on another job. That helps to keep construction separate and less confusing.
You can also select each wall (if the cabinet is associated to the wall) copy and paste it on a blank page.
Hope this helps
Windows 7 Pro/10 Pro 64 bit
NVIDIA GeForce GT 220 1GB
Greg Olson
Postby Greg Olson » Thu, Feb 01 2007, 8:56AM
Thanks for all your help and suggestions
Greg Olson
Postby Greg Olson » Thu, Feb 01 2007, 8:57AM
