Place item mode
Place item mode
Postby Rick Palechuk » Fri, Jan 26 2007, 11:58PM
I have this issue in detail room when I select place item. I don't get the green wire-frame indicating the cabinet. What I do get is a small green dotted circle. I have shaded the screen of the jpeg so you can see it better. Any ideas?
what the.jpg (55.75 KiB) Viewed 1713 times
Postby DanEpps » Sat, Jan 27 2007, 7:30AM
Are you sure that isn't one of Paul Huff's fluted columns instead of a cabinet? :lol:
I haven't seen anything like this before. Is it specific to this job or cabinet?
Postby Rick Palechuk » Sat, Jan 27 2007, 9:21AM
No Dan. I've tried a new room, different libraries, run the repair disc. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Postby Rick Palechuk » Sat, Jan 27 2007, 10:21AM
Found it Dan, the vid card needed a tweekin'
Postby DanEpps » Sat, Jan 27 2007, 10:23AM
Just for grins, zip one of your jobs that do this and post it. I'll see if I get the same results.
Postby Rick Palechuk » Sat, Jan 27 2007, 4:31PM
It's not the jobs Dan, I can lower my hardware acceleration to the third spot from the lowest and it works. That's fine except that I never had to do that before. I'm just backtracking now to see what I have changed that would cause this.
Postby DanEpps » Sat, Jan 27 2007, 4:36PM
Glad you found the culprit Rick. You may have changed the acceleration rate before and forgotten about it.
Did you recently update your video drivers? If so that may have changed the acceleration rate.
Postby Rick Palechuk » Sat, Jan 27 2007, 4:43PM
Yes Dan I have done alot of changes. Now I have to pinpoint the culprit. :wink:
Users browsing this forum: Google [Bot] and 15 guests
