raised panel fridge cap
Greg McCorkill
Postby Greg McCorkill » Sun, Jan 28 2007, 12:28PM
how do i add a raised panel end cap next to the refridgerater?
1125 s mountain 4.esj
(1.78 MiB) Downloaded 99 times
Postby Rick Palechuk » Sun, Jan 28 2007, 1:09PM
Hey Greg, in \"place items\" you can add a door as an end panel.
Plant-on 2.jpg (42.34 KiB) Viewed 1384 times
Plant-on.esa
(179.4 KiB) Downloaded 95 times
Michael Yeargain
Postby Michael Yeargain » Sun, Jan 28 2007, 11:54PM
While in the place item mode also you can double click on the cabinet and s,j,c (adjust cabinet end) dialog will pop up and allow the addition of a door with insets if needed. Negative insets (as always) will adjust outward from the cabinet.
Although adding them as display items will probably give you the best results. The software does not support multipanel doors yet.
Windows 7 Pro/10 Pro 64 bit
NVIDIA GeForce GT 220 1GB
Postby Rick Palechuk » Mon, Jan 29 2007, 12:40AM
But for appearances that can be dealt with by merging two doors.
plant-on 3.jpg (73.34 KiB) Viewed 1346 times
Postby Kerry Fullington » Mon, Jan 29 2007, 7:27AM
Here is a link to another thread on this subject
Paneled Ends
