Build in house doors
Rolf Bergstrom
Postby Rolf Bergstrom » Sun, Jan 28 2007, 7:24PM
I didn't look for other threads on this and it is an easy work around but I was playing with build in house doors and I can't find a way to get sheet stock for the panel material. No matter which door/panel combination is selected, only board stock can be chosen for the panel.
Like I say, it is easy to work around but since we have been discussing cut list enhancements I thought I would bring it up if it hasn't been brought up already.
Postby Rick Palechuk » Sun, Jan 28 2007, 9:50PM
Maybe trick the system Rolf by entering your sheet stock in the board stock area.
Rolf Bergstrom
Postby Rolf Bergstrom » Sun, Jan 28 2007, 10:16PM
Like I said, it is easy to work around. However, the system will still treat it as board stock. In other words, if the door requires a 14-7/16 wide x 26-5/16 long panel you have to have a 14-7/16 \"board\" stock.
There also seems to be a bug in that if you choose to use 5\" board stock to make the panel (you would not typically cut a wide panel from a single board because it would not be as stable as a panel glued up from narrower boards, but that is beside the point as the system allows you to choose any width of board stock to make the panel which makes sense in this respect) you should have three 5 x 28-5/16 boards in the cutlist yet it will only show one 5 x 28-5/16 board.
This kind of leads back to a previous post regarding \"nesting\" of board stock similar to sheet stock but I won't rehash that here.
Mark Taylor
Postby Mark Taylor » Sun, Jan 28 2007, 10:43PM
There are any number of areas where it would be nice to have a choice between sheet and/or board stock...I can think of a variety of situations with the doors where it would be benefical to have a choice. In addition it would be helpful in other areas as well - for example we offer solid wood shelving in our \"better\" cabinets.
Mark
Users browsing this forum: No registered users and 7 guests
