Appliances
Tim Massa
Appliances
Postby Tim Massa » Tue, Jan 30 2007, 10:32PM
Hi everybody,
I'm trying to get a room put together to pitch to a client in a couple of days and I'm having a sorry time with it. The problem is in the room detail editor. It's when I try to load a refrigerator in a corner of the room and it has been resized that the problems start happenning. For some reason the reefer is 1/16 of an inch more than what it is supposed to be in width and depth. Same goes for the other appliances as well. I tried a work around and resized the fridge a 1/16\" less than what I was after (36\"wide) and that seemed to work. Problem is that when you load a cabinet in next to it, it's spotting it as though the refrigerator still has that extra 1/16\". Spent all day tring to figure it outand the clock is running. Any ideas?
Postby Rick Palechuk » Wed, Jan 31 2007, 12:01AM
Set your insert item method to freestyle then you can put the cab where ever you want. Also in settings/preferences>define standard dimensions you can adjust your appliance to cabinet clearance. HTH
Tim Massa
Postby Tim Massa » Wed, Jan 31 2007, 10:18AM
Hi Rick,
The 'standar dimensions' settings were set to the right dimensions, though that is a logical place to start. In fact I put all the fields relating to appliances, walls and cabinets to zero for troubleshooting. Here's what I'm getting:
If I start by resizing a fridge to the dimensions of 36\"wide and 32\" deep and spot that fridge in a corner of a room the resulting fridge, when highlighted, has dimensions that read 36 1/16 wide and 32 3/32 deep. This will happen, regardless if it's placed in a corner or not.
When the fridge is placed in a corner and a cab is spotted next to it, with the 'standard settings' of fridge and cabinet reading 0\" the resulting distance of the cab to wall, with the fridge in between, will be 36 1/16\".
If I change the standard dimensions setting of fridge and cab to 1/4\" and respot the cab next to the fridge the resulting dimension between the cab and the wall, with the fridge in between, will be 36 1/16\".
If I change the 'standard dimension' setting between fridge and cab to 1\" and spot the cab, again, next to the fridge the resulting dimension between the cab and wall, with fridge in between, is 36 11/16\"....?!
Standard setting between fridge and wall, thru all of this, was set to 0\".
Another problem arises when I set base cabs along the opposite wall. After having set the base cabs (all the same depth) I will check the distance of all of them with the wall opposite them. The distance between the cabs and the opposite wall varies! The are all flush up against the wall their being attached to. I checked to make sure that, somehow, the depth of these cabinets could vary by examining them via \"adjust cab features\"/ \"edit cabinet\". They are all the same depth.
I next went to the wall editor and confirmed that the walls are all square or parallel to one another. They are. I'm baffled as to why this is happenning. If it's software related then these problems would be noticed by now by others. Can't seem to figure out what what I may have set up wrong. Going nuts, manual no help. Gunna go for a cup of perspective.....
Tim
Rick Deskins
Company Name: Thermwood
Postby Rick Deskins » Wed, Jan 31 2007, 10:44AM
What is your Dimension Display set as: Decimal or Fractions?
Rick Deskins
eCabinet Systems Programmer
Tim Massa
Postby Tim Massa » Wed, Jan 31 2007, 11:14AM
Dimension display is set to fractions
Walker T Scott
Postby Walker T Scott » Wed, Jan 31 2007, 12:37PM
Tim,
Could you post a room with a refrigerator and a cabinet next to it and cabints on the opposite wall too.
Walker
Tim Massa
Postby Tim Massa » Wed, Jan 31 2007, 1:18PM
Hi Walker,
Here it is.
JoAnne Room.esj
(1.97 MiB) Downloaded 169 times
Walker T Scott
Postby Walker T Scott » Wed, Jan 31 2007, 2:25PM
Tim,
Your walls are crooked, delete the vertical wall on the left and then add a new one. This is an issue and we are looking in to it.
There are other crooked walls too you might want to delete and reapply all the walls one at a time.
Walker
Rick Deskins
Postby Rick Deskins » Wed, Jan 31 2007, 2:30PM
This is really a bug. Dims should work properly on angled walls for appliances. For now, you can hover over the appliance and see the dims in the info window on the toolbar on the left.
Rick Deskins
Tim Massa
Postby Tim Massa » Thu, Feb 01 2007, 8:39AM
The crooked walls seems odd to me. I noticed that they were jagged in the detail room editor display on the left hand side of the room. I went to the wall editor to check their angles and they were all reading perpendicular or parallel to one another. I'm tring to figure out what created the walls running out of perpendicular in the first place. I spoke to Todd over the phone and he mentioned that the wall angle display in the wall editor may not show in decimals and so if a wall is out slightly it may still show it at 90, 270 etc...The question then is when does ninety degrees equal ninety degrees?
Another concern is how the walls were created by me out of square to one another. I typically use start and stop points in the wall editor and use 'incremental' mode for the end points. I don't recall doing any freestyle locating of walls but this seems to me to be one way an out of square wall could easily be created. Again I'n giving myself the hairy eye here and I'll build the walls again to see if this takes out the \"wonkiness\" and let you know if it works out.
Thanks again for the support it's really appreciated,
Tim
