Upper extended end issue
This cabinet should have an extended end with a deck extending 1/2 past the right end, but leaves my deck on the cutlist 1/2 too long. I've lost patience as I have got the correct settings before but not this time
What am I doing wrong? Thx Jack
- ecabinet1.jpg (67.4 KiB) Viewed 10887 times
Not sure I know how to attach the file. Correct me if this one is wrong.
- Upper extended right.hsf
- (213.42 KiB) Downloaded 320 times
Jack,
Not sure if this is the right way to do this, but try setting cabinet width to 52\", right scribe to -10 3/4\", then the right end of the deck to -1/2\" inset.
I think having the neg. inset on the right scribe is making it so you can't neg. inset the right end of the deck and get the right dimensions.
- upper_extended_right_393.hsf
- (222.76 KiB) Downloaded 324 times
Jack,
I think the problem is you're trying to do 2 things, -11 1/4\" inset right end and extend bottom 1/2\" past right end, when the program will only allow you to do 1 or the other.
When I design a cabinet like this, a blind corner upper, I put a face frame over the extended right end. This allows me to put a 1/2\" scribe on the right side and have the bottom extend past the right end 1/2\" and the cutlist comes out right.
I'm still learning this program, but I've found a few times that I just have to cheat the system, as in the above example, to get what I want.
Of course, the next post will be somebody with a simple fix to this.
Jack,
This should do what you want.
Change your right deck construction to Side Flush and put a negative 1 1/8\" inset for right deck and a 1 1/4 bottom inset for your right end.
- jack 2.hsf
- (220.59 KiB) Downloaded 348 times
- jack 2.jpg (14.36 KiB) Viewed 10771 times
