Base cabinet with detached tk
Ted Allen
Postby Ted Allen » Mon, Mar 19 2007, 4:08PM
Hi,
I did a library of base cabs with detached toekicks. I took the cab into the assembly area and added toekicks and then saved the cab as an assembly.
Now I find that whenever I use these assemblys that some of my editing functions when adding these to a room don't work. For instance, they will not snap to the other cabs no matter the place item mode.
Also none of the autofill or resize options work.
if this is the way it is, is there a work around for this?
Ted
Ted Allen
Removed the toekick
Postby Ted Allen » Mon, Mar 19 2007, 4:26PM
HI,
I removed the toekick, left the detached tk and tk height boxes checked in construction settings, then saved as a cabinet instead of assembly and now the cabs \"snap to\" alignment. Also the other functions work.
They are mounted in the room at the regular mounting height with the toekick space below.
I assume I would make a display part the appropriate size to use as a tk?
Ted
greg youngken
Company Name: Grali inc.
Postby greg youngken » Mon, Mar 19 2007, 4:52PM
Ted , I made a seperate toe kick and saved it with my library. then I can place it as an item and easily change the size as needed. For 3- 30 \" cabs I will use 1- 90\" toe etc. HTH.
Grali inc. / Greg Youngken
grali.com
Ted Allen
toekick
Postby Ted Allen » Mon, Mar 19 2007, 6:52PM
Thanks Greg, for the reply.
