how do i make connestoga cp 10 doors white
help,is there a way to change colors on whole cabinets with adding new materials.
The \"alpine 40sheen\" option will display the door in opaque white. It is confusing, because the white display sample is the same color as the background -- -just click in the white space above the word \"alpine 40sheen\". Have a look at the options I selected in this screenshot. Get there, and you'll have a white door.
- shot.gif (37.39 KiB) Viewed 4840 times
- shot.gif (37.39 KiB) Viewed 4835 times
Re: how do i make connestoga cp 10 doors white
David,davidklehn wrote:help,is there a way to change colors on whole cabinets with adding new materials.
There are various ways to do this...
A: Go into the construction settings menu, and change the material globally. Note: this will not affect Face Frames. You will also have to go into the FF portion of the construction setting area to change the material for the FF.
B: If you have a cabinet in the Cabinet editor, you can highlight the part you want to change. Right click, then goto the match texture option, then click on a part you would like to change the texture to.
C: In the layout editor, while in "Detail room", highlight the cabinet, then right click. Goto change materials, "Sheet stock". A dialog box will open and promt you to select a new material for individual parts.
Try these options, and let me know if you need further assistance.
Re:
It actually seems like the title and post ask two different questions. I only addressed the first. The second question has been discussed at length previously, and your summary was a good reply to that larger question.Todd Miller wrote:Sorry,
I guess I need to read the thread topic. Dan you are correct.
