Shop Drawings
JoeyLowe
Shop Drawings
Post by JoeyLowe »
Hi all:
Have another question. How you more experienced users handle your drawings? What I mean is will eCabinets allow you to draw title bars/insert page numbers, etc. as is found in normal shop drawings? For instance, in my shop, I need two sets of drawings, one for the customer to approve and one for the cabinetmakers to use. Both contain separate information.
Thanks!
J. Alexander Lowe & Sons, Inc.
104 Davis Street, Gilmer, Texas 75644-1821
(903)680-2297 Cell: (903) 445-9350
Michael S Murray
Post by Michael S Murray »
Hey Joey,
This has been discussed several times and I bet if you do a search you can find what your looking for. It is possible to do title blocks and such.
Mike Murray
mike@versatilecabinet.com
Michael Yeargain
Post by Michael Yeargain »
Joey,
First, I created a text file with nearly every verbage I could possibly use in the shop drawings. (This keeps me from retyping everything) I also created a dxf file (it was tricky but it imports exactly in the right place every time) I then bring in the dxf title block I made into the LDE, I then go and copy the text and click Note mode on the LDE and hit control \"V\" on the key board. This pastes the copied text into the LDE.
I know this is kind of vague but it works. And with a little practice you can kick out a set in no time.
Hope this helps
Last edited by Michael Yeargain on Fri, Apr 13 2007, 6:06PM, edited 1 time in total.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Michael Yeargain
Here is the title block I used in this LDE it is for the landscape layout...I made it in Autocad.
32Gigs DDR4
Corsair RM650
JoeyLowe
Post by JoeyLowe »
Thanks for the replies. I figured that it must have been addressed before. My search terms weren't turning up much info though. Thanks for the title bar file too. I typically send drawings out for client approvals and I need to put some standard language on each page. Thanks again. Aiken, S.C., eh? I'm from Rock Hill but have lived in East Texas for the past 25 years.
