equalizing spaces in the partition editor
I have been trying to equalize spaces between 4 partitions in a cabinet. I've done it before easy but cannot now. The help manual says to put in partitions then select all the spaces with ctrl and left click, and then hit equalize. My problem is that I can't select more than one space. If I hold down the ctrl key and click the left mouse button to select another space nothing happens. I have upgraded to the most recent version of ecabs and now it seems i am having this problem (only in the shelf/ partition editor so far). My ctrl key works fine everywhere else. WHAT am i possibly doing wrong here? Argh!
Jon Reichert,
Sounds like a framed cabinet issue that has been around for a while. Is this a framed cabinet?
Sometimes, this can be resolved by removing the face frame and reapplying it.
It is as simple as you mentioned. And, that is the way. CTRL and left mouse click on each openning.
Try removing the face frames and put them back on.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
Jon
When in the shelf/partition editor, click in each space and look at the width box to the left. Check each one and see if they are the same width or not. Maybe they are already equal, and that might be why you do not see them move. If they are not then post or email me your files.
Thank You
Justin
Thank You
Justin
Re:
Jon,Jon Reichert wrote:Thanks for the response. Unfortunately, not a framed cab - see if i can attach a screen grab of what I'm working on
What is running behind the eCabs screen? Is it a screen capture program? If not, I wonder if you might have something interfering with the program.
Are you running on Vista?
Al
- Jon Reichert 11111_249.jpg (206.43 KiB) Viewed 10953 times
Re:
Ahh, hmmfff, uhhh, ohhh... Duh!!!!!!!!DanEpps wrote:XP Pro Al, take a look at the top right corner of the image (not that I've ever missed seeing anything like that ).
Thanks, Dan! I was concentrating so much on the rest of the image that I totally missed this somewhat important item .
Jon,
PLEASE ignore my post totally. Thanks!
Al
Jon,
Are you using a wireless mouse? Batteries. Take a look at the mouse settings. I'm sure you are doing the right things. But, sometimes it's the simple things that get in the way.
Go to the mouse settings and check the double click speed there. It could be in the mouse settings...
Just to double check... you are using the \"CRTL\" and left mouse button right?
Last edited by Michael Yeargain on Tue, Sep 18 2007, 4:46AM, edited 1 time in total.
32Gigs DDR4
Corsair RM650
32Gigs DDR4
Corsair RM650
still having problems with that spacing stuff - can't seem to figure it out - I have been equalizing things manually but it's a pain. I will post my file now thanks for the help! Hope you can open these
Jon Reichert
jon@boxdesigns.com
Jon Reichert
jon@boxdesigns.com
- problem2.hsf
- (244.02 KiB) Downloaded 337 times
- problem2.jpg (14.81 KiB) Viewed 10970 times
I don't know - maybe i have to reinstall ecabs or something - for some reason this ctrl key isn't working here. I have tried reinstalling the key board and going through the help manual - tested the left and right ctrl keys - checked for a good wireless signal - checked the mouse signal -...all i can say is that the ctrl key functions properly everywhere except ecabs! Weird. And apparently, the file is fine since Rick said it worked ok. Hmmm. I have recently come across other moments when the ctrl key seems to work sporadically - like in the line drawing area. I noticed the other day that i can't do ctrl z to back up a step all the time. Tested ctrl p and that brought up the print dialog no problem. Ctrl S (save) works fine and ctrl A (all select). Weird weird weird. Any other thoughts?
- Company Name: Dan Epps
So, you are using a wireless keyboard and mouse? If so, try the wired variety if you have them. This will help rule out the wireless keyboard and mouse (and their associated drivers). I have had lots of intermittent problems related to wireless keyboards and mice. Now I use only the wired varieties.
