So as i Do a TWD file suddenly i'm getting a memory error on larger files is this something a install and re-install can fix, has it been corrupted? I can load the same file on another computer(using the exact data base of cabinets that i copied over to it) and It Twd's it just fine...So i'm guessing its an issue with the program some how? or do i have something on that i shouldn't?
The Error message i am getting is.
CiceroUIWndFrame : Ecabinets. exe application error
The instruction at \"0x73dd11c7\" Referenced memory a \"0x00000004\" The memory could not be \"read\"
Soooo annoying and it just suddenly happened last night:(
Memory error?
- Company Name: Dan Epps
I noticed in the error \"CiceroUIWndFrame\" and did a search on it. Here is what I found:
You might want to give that a try to see if it helps.Recently, my system has been crashing more often, due to a process or program \"CiceroUIWndFrame.\"
I found out that this is the \"Speech and Handwriting Recognition\" part of Office XP. To de-install it, go to
\"Control Panel\"
\"Add/Remove Programs\"
\"Microsoft Office,\" click on the \"Change\" button
browse to \"Office Shared Features,\" \"Alternative User Input,\" and select for Speech and Handwriting Recognition (both) \"Not available\" from the drop-down box.
Perform the change and the CiceroUIWndFrame messages disappear. Took just a second, and you don't even have to restart your system or insert the XP Office CD.
