Hi All eCab users
I am having a spot of bother at the moment. I have had computer crashes and have had to format my desk top and laptop, losing all programs. When I istalled eCab again, I got one new code, then went after a second code only to be told I had received my maximum number of codes allowed. Now, I could only register one comp with eCab. When I went online to register V5, I got another message telling me it had expired: now I have no ecabs again.
I emailed Jason who was good enough to get me a new code via Thermwood, and when I went to register the new code on line, I got the same reply: your copy of eCab has expired. I tried to regenerate yet another code, once again I have used all I am allowed. Still no eCabs for me to use.
I am wondering if it will not let me use the V5 disc because it needs all the updates to make it valid for registration. I can download the latest update, but cannot download all the previous updates for V5.
Can anyone HELP me, and has anyone else had this problem?
Cheers All, Russell \"Desperate\"
Code regeneration and updates
Russel,
One thing is for sure, concerning the updates. You only have to use the most recent update from the Internet. This update will supersede any other update you may have.
Have you tried to down load the newest update?
As far as the codes, I just had to reformat one of my computers and of course had to get a new Reg Code. Justin had one sent to me. They may have to reset your reg code generator account if it can be done.
What is your comp specs and what OS are you using?
Windows 7 Pro/10 Pro 64 bit
AMD Phenom 9650 Quad-Core Processor 2.3Ghz 8GRAM 1TB
NVIDIA GeForce GT 220 1GB
System
Hi Mike
I run XP, I didn't have any problems with eCab until I tried to reinstall it in both systems. The thing that is troubling me is that it tells me my V5 disc has expired and I can't regenerate a code anymore.
Mike, it will be some time before I am online again, so I won't be able to confer with you for a while.
Cheers Russell
Cheers Russell
Registration and Codes
Hi Justin
I will do as you suggest in regard to the update, I was of the opinion that that each update performed a different function. If you could send me another code that would be much appreciated. Can you tell me why I keep getting a code limit message, I didn't know there was a limit on how many we could have.
Thanks for the advice from Michael and yourself.
Cheers, Russell
Cheers, Russell
Registration & Code
Hi Justin, Michael
I have downloaded the update, and when I opened the program it started up fine. No more out of date notice: I feel great.
I still need another code to get the program up and running in my laptop.
Thanks again!
Cheers, Russell
Thanks again!
Cheers, Russell
Users browsing this forum: No registered users and 66 guests
