22 1/2 degree miter
22 1/2 degree miter
Is it possible to miter a custom molding at 22 1/2 degrees? I can do 45 degree miters easily on custom moldings using the chamfer tool in the parts editor before profiling the edge of the display cube, but I can't figure out how to do a 22 1/2 degree miter.
- Company Name: Dan Epps
Re:
Come on Mike...you know the answer to thisMichael Yeargain wrote:Kerry and Dan have been doing great work with moldings. Maybe they can help here.
This is a little beyond my knowledge at the moment.
I presume by custom molding you mean what you created using the Part Editor. If this is correct, all cuts must be made before any edges are profiled.
In other words, cut the ends at 22.5 degrees before profiling the edges. How? Make sure you are in Contour Mode of the Part Editor. Right-click and choose Angle Snap. If not previously set, you will be prompted to enter an angle. Enter 22.50 and click OK. If already set you will have to repeat the actions to set the angle.
Now draw a 22.5 degree line across the end of your unprofiled molding and close the contour then cut it off. After completing this you can profile the edges.
I was thinking you needed to use a 22 1/2 deg cutter to get the bevel. I am aware of the use in the part editor but I really thought it was another step, such as an angle cutter instead of just chamfering the end.
If this is so. what would the angle be, if I chose to cut a 11.25 deg angle or a 45 or even a 90? The angle would be right but there would be no back cut to the part. Unless you used a cutter relative to the angle. Right?
There needs to be an additional 50% of the thickness of the part per side to do a 45, for example. and an additional % per angle at a different ratio for all others.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
