Peter,
You wrote
I opt for the method I have shown in the original thread because it allows me to change depth of the cabinets. I would actually inset the middle cabinets at least two inches so that they look like they are sitting on top of the base. Then I bump the upper cabinets out a little to add interest there. I dislike the wall of doors look. This seems to help some.Dale,
Kerry is right about the moulding. However, I apply a trim board across the joint instead of in it. This conceals any mis-alignments caused by floors or walls as the cabs are joined together. Either way, it is an opportunity to add some architectural elements to make the assembly more interesting to look at.
Merry Christmas to all!
regards,
Gene,
You wrote:
Your 3mm margins are the thing I am trying to eliminate. That is my main reason for disliking frameless construction. There is no division between the elements. You need space between doors and drawers. There needs to be elements that stand proud and some that sit shy as well as moldings to create shadows and depth to create interest.I'll be installing a kitchen next week with two two-stacks and one three-stack, no intermediate moldings, 3mm margins everywhere.
Details similar to what the original poster showed. I'll post some photos of assembly details, plus some of the finished elevations.
How someone builds their boxes is the least important part of a cabinets beauty. The picture you posted in the original thread of the Neff cabinets is a prime example of this. The beauty of those cabinets came from the trim and decoration. The fluted columns, the bump ins and outs, the stacked crown, the corbels and capitals and how the designer put it together, not the frameless boxes. The same goes for framed boxes. It is what you do on top of the box that counts.
My adding moldings and depth changes to the cabinets in the original post (whether they were built frameless or framed) was just an attempt to add beauty (maybe only in my eyes) to the job. It was not an endorsement or criticism of a particular building style. I would also add pilasters of some kind between certain columns of cabinets in the original posters job for the same reason. It breaks up the wall of doors and adds interest.
