Dimension a Room
Dimension a Room
I am just getting started with eCabinet and love it.
I have created a room and would like to put dimensions in the drawing i.e. width, length distance between windows etc.
Is there a way to do that?
Larry
Larry
Larry
Aside from being able to dimension to openings that are cut from walls there's another major advantage to working with holes instead of just images. Using display boards you can then easily put door and window casing in the openings and then add doors, trim, and windowsills:
Thus adding yet another layer of realism to presentations...
Philip
Philip
Re: Dimension a Room
I know this is an old topic, but I'm not having any luck with being able to make windows or doors so I can put dimensions with them in the line drawing editor. Any help?
Lee are you using the pre-set doors & windows or wall cutouts?
M
M
The only cut outs I find are in the items to place. I tried those, but was unable to dimension to them. I don't know if that was the right cut out or not.
Larry
In V5.2 you will be able to place a dimension on windows and doors.
YESSS!!!!! When will this v5.2 be available?
Being a throwback to a few generations, what does that mean in laymans terms? And I still don't know how to make wall cutouts.
Lee what I meant by wall cut outs, did you edit any walls in the wall editor ie; door openings or windows? Those can be dimensioned in the line draw editor.
Mike
Mike
Thanks, Mike. Yes I finally figured it out. Now if we can get them cracken' on v5.2 life will become a little easier.
