Hi
I have being playing around a little with the Display of a Kitchen an i cant get a sink to snap onto the bench top or change the size and mount height.
As well i have tryed doin the same with a micro and same problem if anyone could help would be great! And is there a way to update the Display Objects Libary to get more range and a wall oven in there
Tim
Display Objects
- Company Name: Creative Kitchens and Interior
- Country: NEW ZEALAND
Re: Display Objects
Hi Tim I use display cubes for my sinks.Make the length and width whatever you want,I usually set the depth at 40mm (you guys would say 1 1/2")it just makes it easier to see and highlight when viewing from elevation.If you havent got a suitable image just source and save one from the internet.Select"stretched" for the image when you load it.Also make sure you associate it to a wall in your layout.Set the move increment and then use the arrow keys in plan view to position it on the bench.Then go to elevation and use the arrow keys to move it to bench height.
