Hi guys,
has anyone of you ever had depth or fit clearances with the backs of any cabinets. I keep having that problem. The problem is that I cannot find where the problem is. If it's the program or the machine. I end up going 1/32" deeper on the full dado on the back. I wonder if its the same problem as the fit and depth clearance mistake on the drawer boxes once. I always change the daylight on the bit that makes the back dado and it cuts fine but may be the programmers can take a look or someone else can advise me how to fix that if they've had the same problem. Thanks guys
Cabinet Back Issues
- Georgi Baltov
Cabinet Back Issues
Top Notch Cabinets
- Scott G Vaal
Re: Cabinet Back Issues
Georgi,
Post one of your cabinets that you believe presents this issue. We will take a look at it and see if there is any obvious problem. As of now, I do not know of any issue with this.
Michael S Murray
Sounds like a material thickness issue to me. Have you checked the actual thickness of your back material and set that up in your material ?
Mike Murray
mike@versatilecabinet.com
