Why can't I update my software version?
Denis L'Heureux
Postby Denis L'Heureux » Tue, May 06 2008, 4:20PM
I tried downloading automaticly and it installs but when I open ecab, it still shows v5.1 build 5. So I tried with manual download and install and it first has to uninstall (weird since it does not show it as installed) and then install but still show 5.1 build 5.
WHY?
Michael S Murray
Re: Why can't I update my software version?
Postby Michael S Murray » Tue, May 06 2008, 5:12PM
Are you opening the software and then shutting down, it should then show the update.
Mike Murray
mike@versatilecabinet.com
Denis L'Heureux
Postby Denis L'Heureux » Tue, May 06 2008, 7:06PM
Yep did that. Installed, rebooted the computer and still showing 5.1 but if I try installing again, it says it has to uninstall 5.2
Michael S Murray
Postby Michael S Murray » Tue, May 06 2008, 7:25PM
Hmmm, I had beta on one computer and regular version on another. I saved the update to my desktop, then ran it from there. Both times the software still showed up as 5.1 until I actually opened the program and then it changed to 5.2.... Are you saving the update and then running it or are you trying to run the update from the web? I know I have always been told to save the update on your computter and then run it from there.Maybe some one more knowledgible will jump in.
Mike Murray
Denis L'Heureux
Postby Denis L'Heureux » Tue, May 06 2008, 7:28PM
Tx Michael
Actually, I have tried every which way possible. First from the web and when that didn't take, I downloaded the file to my computer and ran it from there. No difference in the outcome.
My next attempt will be to uninstall the whole thing, reinstall from the CD and see if it will pick up the update on the install.
Denis L'Heureux
Postby Denis L'Heureux » Tue, May 06 2008, 9:17PM
Getting worst now. I uninstalled and reinstalled and now I get this error message. The problem is still the same though...can't run 5.2 and if I try installing it, it says it is already installed. I need major help here.
Ecab problem.png (13.16 KiB) Viewed 1725 times
Rick Deskins
Company Name: Thermwood
Postby Rick Deskins » Wed, May 07 2008, 7:03AM
Rerun the 5.2 update and let it uninstall. then run it again and let it reinstall.
Rick Deskins
eCabinet Systems Programmer
Justin Melhiser
Postby Justin Melhiser » Wed, May 07 2008, 7:20AM
Denis
If you need a code please send me an email and I will get one sent out to you.
Larry Epplin
Postby Larry Epplin » Wed, May 07 2008, 7:43AM
Denis,
Sorry to hear you're having trouble. So from what you are saying the update ran successfully, but you are not seeing 5.2. It sounds like your virus protection software or a firewall is stopping the update from placing the necessary files. Try this...
1.) Re-run the 5.2 Build 1 update and select the "Remove" option. This will merely remove the update installer files.
2.) Insure you have any anti-virus software applications and/or firewalls disabled. This includes Windows firewall.
3.) Now run the 5.2 Build 1 update again.
Denis L'Heureux
Postby Denis L'Heureux » Wed, May 07 2008, 10:33AM
Larry, it seems it was my Anti-Virus. Why I have not thought of that? Dunno. But It now works. I have removed the 5.2 and re-installed it and it is now working fine.
Thanks for the help one and all.
Cheers
Dean Fehribach
Site Admin
Postby Dean Fehribach » Wed, May 07 2008, 2:01PM
Yes, Dennis, it was your antivirus software and here's why.
More and more antivirus software are preventing the spawning of EXE files from the TEMP directory. When you launch the 5.2 updater, it decompresses the installer to a directory in the user's TEMP folder and then spawns the installer's EXE from there. The antivirus software didn't like that and was blocking.
Dean Fehribach
I.S. Mgr., Thermwood
Denis L'Heureux
Postby Denis L'Heureux » Wed, May 07 2008, 4:50PM
I will try and remember that next time LOL
Cheers
Users browsing this forum: tim lucas and 11 guests
