E-Cabs crashing
Rob Perry
Location: Qualicum Beach, Beautiful British Columbia, Canada
E-Cabs crashing
Post by Rob Perry »
I've just been attempting to fine tune a job for production tommorow morning & Suddenly E-Cabinets just wants to crash if I Hide Countertops & attempt to Select a Base cabinet. This job file was working fine before updating to 5.2.... I've been attempting to attach the file but no go at this time.
I'll try attaching the error message screenshot
Also I'm attachin a screenshot of a strange window regarding a range ( There is no range in this file ) :?
Strange window.jpg (54.49 KiB) Viewed 5265 times
Rob
Justin Melhiser
Re: E-Cabs crashing
Post by Justin Melhiser »
Rob
if you can not post this file can you try and email it to me? I will see if I get the same message or not.
Rob Perry
Re: E-Cabs crashing
Post by Rob Perry »
Hi Justin
I tried e mailing the file but received a message that file is to big for server ( 14.3 mb )
Mabe I'll try to zip it or something.
Rob
Rob
Rob Perry
Re: E-Cabs crashing
Post by Rob Perry »
Trying Zipped File
basement office (revised).zip
(5.74 MiB) Downloaded 455 times
Rob
Scott G Vaal
Re: E-Cabs crashing
Post by Scott G Vaal »
Rob,
The job has a corrupt appliance segment in it that originated and existed in the 5.1 job (not sure how it happened). Hence the tool tip pop up on your 1st picture posted here. 5.2's new layout does not seem to tolerate it as well as 5.1 did. We will have the software look for this situation in the future and heal itself.
The good new is you can fix this right now by following these steps.
1.) Load the job
2.) From the Right click menu choose Select-> Select All Appliances
3.) Press the Delete key on the keyboard and answer OK to the "Are you sure?" message.
4.) Save the job and all should be fine.
Let me know if this does not work for you.
Rob Perry
Re: E-Cabs crashing
Post by Rob Perry »
Thanks Scott
That did the trick. :D
I was looking off in the distance etc to find a applience to delete but I could not find one & I didn't notice the select all applience feature.
I learn something every day...
Rob
