Toe Kick problem
Toe Kick problem
How do I place a 3" x 4" toe kick around 3 sides of my cabinet?
Re: Toe Kick problem
DuWayne, I use a resizable kick that you can attach to the bottom of your cab, or place in your room first.HTH
- TK.jpg (8.96 KiB) Viewed 9003 times
- TK.hsf
- (114.02 KiB) Downloaded 315 times
- Company Name: Two Mile
Rick,Rick Palechuk wrote:DuWayne, I use a resizable kick that you can attach to the bottom of your cab, or place in your room first.HTH
Do you rather place the toe kick at the custom layout, instead of in cabinet?
I always have a hard time with the finish of my toe kick. Usually it ends up the sides not being finished. I have tryed all kinds of things.
Is there something that I am doing wrong? Do you have any suggestions?
- B18_toe.JPG (20.99 KiB) Viewed 8855 times
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Designer Specialist
Sergio, we do are TK separate and apply finished product after. Post the cab and I'll take a look at it.
Rick,
Thank you for your reply.
Here is the cabinet. I am not sure if I was clear before, but my toe kick is not separate from the cabinet; they are all one piece.
- B18.hsf
- (1.22 MiB) Downloaded 320 times
Sergio Fetter
Designer Specialist
Designer Specialist
Sergio, let me know if this works for you.
Rick,
This is great. How did you do that? I have tried all kinds of things. I guess I haven't tried what you did.
Thanks!
Thanks!
Sergio Fetter
Designer Specialist
Designer Specialist
Sergio, if you hover over the TK you will notice it is a stretcher now. Without knowing what you need in terms of cutlist, method of construction, or display purposes I chose display. You can add a user part name to it for your cutlist. HTH
Rick,
Thank you very much.
That will do it for this job.
Let me ask you this... What is the advantage of using a toe kick that is not attached to the cabinet like I did. In my understanding you use a different type of toe kick right?
When you do that, how do you place the cabinets in custom layout? I noticed in someone else's post that they had all this toe kick layout, but not cabinets. Is it simpler to do that way?
Thanks again.
Thanks again.
Sergio Fetter
Designer Specialist
Designer Specialist
Sergio, in general I think it's personal preference to how you build cabinets with dictates what method a person uses. Some use a gable that goes to the floor, others attach a loose base to each cab and some may use levelers. We like to build bases from 3/4 plywood for strength and moisture resistants. We also find it easier to laser in a room full of bases first, then mount cabs on top.
