Top Rail
Gary Puckett
Company Name: The Woodworkery
Top Rail
Postby Gary Puckett » Mon, Jun 16 2008, 7:17PM
Does anybody know how to put a arch on the top rail of a cabinet? I think you use a standard rail make it wider and then take that part to the part editor and arch it. But how do you control the radius and the start /finish points?
Thanks Gary
jerry johnson
Re: Top Rail
Postby jerry johnson » Mon, Jun 16 2008, 7:32PM
You are right, Gary. Take the top rail to the part editor and select the three point arc icon not the circle. That way you can designate the two end points and the center point of your arch. If you need to figure the radius go to http://www.curvedmouldings.com/download/archchrt.xls and you can download a chart for figuring all types of arch stuff. Hope this helps. 8)
Gary Puckett
Re: Top Rail
Postby Gary Puckett » Mon, Jun 16 2008, 8:03PM
Thanks Jerry but how do you cut the arch out of the face frame rail?
jerry johnson
Re: Top Rail
Postby jerry johnson » Tue, Jun 17 2008, 1:33PM
Do you have a cnc router? If so, you would need to create the top rail as a display panel (the panel would be the same size as the top rail) separate from the face frame, take it to the part editor, and create the geometry needed. This part could be cut on the router. It might be small so holding it down may be an issue. Also, I use a chip breaker type bit when cutting lumber (if the top rail is lumber). If you do not have a router cut it any way you want. (old school) 8)
Users browsing this forum: No registered users and 15 guests
