Reinstall
Douglas Walters
Reinstall
Postby Douglas Walters » Fri, Aug 22 2008, 2:14PM
I reformatted the hard drive, turned off my antivires and tried to install eCabinets and get the following error,
1305.Error reading from C:\Program Files\Thermwood\eCabinet Systems\hoops1106.dll. Verify that the files exists and that you can acces it. I have a M70, cleaned the disk(Version 5), tried to reinstall with the same error.
Thanks for helping with the reinstall.
Douglas Walters
D Walters
Wood Architects
Rick Deskins
Company Name: Thermwood
Re: Reinstall
Postby Rick Deskins » Fri, Aug 22 2008, 2:50PM
After installing from the disc, you need to install the latest patch.
http://downloads.thermwood.com/eCabinetSystemsV5-2Build-2.exe
Rick Deskins
eCabinet Systems Programmer
Douglas Walters
Re: Reinstall
Postby Douglas Walters » Fri, Aug 22 2008, 3:13PM
Hi Rick,
The error comes up before it finishes the install from the disk. I can't even think about updating yet.
Douglas Walters
D Walters
Wood Architects
Re: Reinstall
Postby Rick Palechuk » Fri, Aug 22 2008, 4:52PM
Douglas, try updating or reinstalling the drivers for your CD-ROM or DVD drive.
Douglas Walters
Re: Reinstall
Postby Douglas Walters » Thu, Aug 28 2008, 9:37PM
Thanks Rick,
Updated the firmware, uninstalled AVG, rebooted, tried to reinstall ecab, 80% done and a different error 1305 comes up.
Errorreading from file C:\Program Files\Thermwood\eCabinet Systems\hardware\Wood Components\Hafele\Hf-194-78-335.hsf. Verify that the file exists and that you can acces it. Retry or cancel. Retry comes up with the same error.
The Hafele component should be on the disk.
What should my next step be? :wall:
I retried and it is the same as above except says .jpg.
Where would I verify this exists? :cry:
D Walters
Wood Architects
Re: Reinstall
Postby DanEpps » Fri, Aug 29 2008, 6:20AM
Try uninstalling eCabinets before starting the reinstall.
Are you running Vista? If so, make sure you are following the Vista installation instructions in the sticky at the top of the forum.
Douglas Walters
Re: Reinstall
Postby Douglas Walters » Wed, Sep 03 2008, 2:46PM
Hi Dan,
eCab has not been installed on this after the reformat. I am running XP and have checked the add/remove programs and there is nothing to remove.
D Walters
Wood Architects
Douglas Walters
Re: Reinstall
Postby Douglas Walters » Wed, Sep 03 2008, 6:13PM
Hey Guy's,
Can anyone from Thermwood help out? I need to get this installed.
D Walters
Wood Architects
Justin Melhiser
Re: Reinstall
Postby Justin Melhiser » Thu, Sep 04 2008, 7:49AM
Doug
Try to download the latest update first from the internet. I know that you do not have the software installed yet but I am thinking since it is a version 5 disk, if you download the update frist and run it then try to install the cd. If this does not work you can email me, call, or post back on here.
Users browsing this forum: Google [Bot] and 11 guests
