Can not generate cost reports
ScotAcree
Company Name: Scot Acree Woodworkig LLC
Post by ScotAcree »
Could someone try to open this job and run a cost report?Mine shuts down when it gets to calculating sheet goods.
Scot
test1.zip
(5.54 MiB) Downloaded 261 times
Justin Melhiser
Re: Can not generate cost reports
Post by Justin Melhiser »
Scott
I am looking at your file now and will let you know.
ScotAcree
Post by ScotAcree »
Justin,
Let me know if you need more info.
Scot
Justin Melhiser
Scot
There is a cabinet that you can not see in your room. See image below. You should be able to click where this cabinet is and delete it. If you need it in there then change the sheet stock in the room, just select the same material for each one. This will reginerate all the cabinets and the hidden cabinet will now be in view. This will allow you to create your cost sheet.
hidden cabinet.JPG (14.27 KiB) Viewed 3625 times
ScotAcree
Post by ScotAcree »
Justin,
Works like a charm,thank you for finding this.Lesson learned.
Great service Thermwood Team.
Scot Acree Woodworking,LLC
