Door changing size
Lamar Horton
Door changing size
Postby Lamar Horton » Mon, Nov 17 2008, 10:59AM
I have an angled upper corner cabinet with two doors, upper and lower, the upper door maintains it's size with the proper overlays but the lower door does not. When I add the door it correctly sizes it but when I go to the main area from the door area the overlays vanish and the door resizes itself.
Here is the cabinet
Upper Corner w_garage.hsf
(570.02 KiB) Downloaded 90 times
Walker T Scott
Re: Door changing size
Postby Walker T Scott » Mon, Nov 17 2008, 1:10PM
This is a bug and I have passed it along to the programmers. This is something you could try for a work around. Add a bottom rail that has a width of .125 to the bottom opening then change your bottom overlap to 0 when you re add the bottom door. Hope this works for you and sorry for the inconvenience.
ScotAcree
Company Name: Scot Acree Woodworkig LLC
Postby ScotAcree » Mon, Nov 17 2008, 1:13PM
Yes,
I added your .75" bottom rail back and it started resizing the correct width.
Scot
Lamar Horton
Postby Lamar Horton » Mon, Nov 17 2008, 3:15PM
Thanks Walker that did the job.
